RCU Forums - View Single Post - CNC Machine
Thread: CNC Machine
Old 05-05-2010 | 12:37 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: CNC Machine
My Machine is built from extruded aluminum box rails with aluminum plates for the gantry and steel tubing for the slide rails. Aluminum angle and roller bearings where used to create the slides. Although this system works perfectly, If I where to build another I would probably go with linear slides for the gantry just to add additional precision. I can cut 1/4" ply at about 20-25in/min, balsa can be cut as fast as I desire. I have cut aluminum with this machine but it is hard on the router.
ID:	1431277   Click image for larger version
ID:	1431278   Click image for larger version
ID:	1431279   Click image for larger version
ID:	1431280   Click image for larger version
ID:	1431281   Click image for larger version
ID:	1431282   Click image for larger version
ID:	1431283   Click image for larger version
