I'll betcha 50 cents its the air bleed hole. This has been discussed many times here with the same symptoms, heck I even wore a small indentation in my onion with the same problem.
You most likely can correct it all by taking the carb apart and cleaning it with attention to the bleed hole and setting the bleed screw properly.
