RE: Evolution 58cc Engine Dying On Me
Ok guys next question: I may or may not have previously stated that I'm fairly new to RC. I'm sure you might have guessed that by now. I've got a 3 line fuel system for the fuel tank. One line for fuel-dot. 2nd fuel line for the vent and 3rd fuel line goes to the carb. Very simple setup. My Question is regarding the fuel dot line. Do I add a clunker and a small piece of fuel tube to that line inside the tank so it's easier to fuel and empty the tank with out having to flip it over? Is there any kind of issue using two clunkers in one tank? Or should I be doing something else? What are your thoughts.
On a positive note. I've replaced all the fuel lines, inside and out, replaced spark plug, cleand out carb, got a new batch of gas. Got a new battery now I have to figure out where to put the stupid thing since it weighs twice as much as the original. I'll have to redo CG. I'm strongly considering using my 1400mAp battery for now. Too bad it's 10:00pm and I have no lights outside I would be trying to get her started right now.
