RCU Forums - View Single Post - One way to make a prop hub
Old 05-05-2010 | 10:39 PM
Scota4570
Default RE: One way to make a prop hub
A flat bed scanner is a good way to do little flat objects. Here are the boring bar pictures. The black marks are for depth of cut. Basically a boring bar is a lathe tool sideways on the end of a stick. If you can make a lathe tool bit you can do this. Old two flute milling cutters make excellent boring bars. Drill bits work too.
ID:	1431501   Click image for larger version
ID:	1431502   Click image for larger version
ID:	1431503   Click image for larger version
ID:	1431504   Click image for larger version
