RE: Fastech
AB, I have an idea where you got your advice at about breaking in an engine and it's a BAD idea! The only way to properly break in an engine is to run it on the water where it will get the proper load on the engine which you aren't going to get on the bench.
What fuel you plan on using in any engine should be the one that you use from day one.
