RCU Forums - View Single Post - Dehideral on a wing..
Old 05-06-2010 | 11:33 AM
Rune
Default RE: Dehideral on a wing..
you will  normally need some dehiedral , but if the design is almost like everyone else make the wing flat on the toop , make the highest point off root and tipp template at same height on the table when you cut the wing ...remeber to make one left and one right wing!
This will also make the root easy to join or fit to the fuse if your using a wing tube.
