RCU Forums - View Single Post - stuffing
Thread: stuffing
Old 07-21-2003 | 05:59 PM
ZAGNUT's Avatar
ZAGNUT
Default stuffing
the crankcase in a two stroke is used as an air pump so if you increase its compression ratio you make it more effecient.
i've read about the cork trick in a model engine book from the fifties and even back then it wasn't recomended because it would cause the piston crown to overheat.
dave
