RCU Forums - View Single Post - A question of balance!
Old 05-06-2010 | 01:43 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: A question of balance!
ORIGINAL: TonyBuilder
JohnBuckner, so the stabilizer is not the level point, is it the plane as a whole?
I will keep the nose just slightly down for now. I know that you can move the CG back for beter performance
Yes a visulized centerline of the fuse is correct for balance purposes.
Yes, "slightly down" is fine. I always commuicate CG info without that fudge factor knowing its going to be fudged on even more down the line and measure with fuse level however simply because there is no way practical way to communicate that fudge factor with 'slightly' meaning very different things to different people.
John
