RE: Help on ESC
Thank you for the advice. The suggestions you have are in line with other reading I have come across. I have one final question: the motor documentation says the speed controller requirement is 25A. If I were to purchase a less expensive ESC that ran at say 8A, what would be the effect on the system? Would the controller simply not function or would it limit the max speed of the motor?
Thanks again
