RE: New To Electrics
<div class="shape" style="PADDING-BOTTOM: 2.88pt; PADDING-LEFT: 2.88pt; PADDING-RIGHT: 2.88pt; PADDING-TOP: 2.88pt">Actually it is somewhat below my specs. kV is right but the amp levels are a bit low. <span lang="en-US">Continous current is 18A I was targeting 20 - 23. Max of 22A is usually a 15 second number so you better not leave that throttle open.
It says max power of 360W but I think that is a mistake. 11V X22 Amps ( max) = 242 Watts. 11X18 = 198 watts. Assuming they are not out and out liers, that has to be a typo. And a claim of 98% efficency seems VERY optimistic. Something in the low 80s is more likely.
Note also that props are smaller than what I recommend. ( 8" x 5"/ 8" x 7"/ 9" x 5") although 9X5 is close to 9X6. I modeled a 1200kV motor with a 9X6 at 22 amps, so this one with a 9X5 is probably right at 18 amps.
This one is OK, but the a little on the light side for my tastes. I think performance would be a bit weak. I would not choose this one.
</span>
<p class="MsoNormal"><span lang="en-US">
Rotational Speed 1200 (kv) RPM/V</span></p><p class="MsoNormal"><span lang="en-US">Continuous Current 18A</span></p><p class="MsoNormal"><span lang="en-US">Max. Current 22A</span></p><p class="MsoNormal"><span lang="en-US">Input Voltage 6 - 11.1V</span></p><p class="MsoNormal"><span lang="en-US">Max. Efficiency 98%</span></p><p class="MsoNormal"><span lang="en-US">No Load Current 0.8A</span></p><p class="MsoNormal"><span lang="en-US">Internal Resistance 98mΩ</span></p><p class="MsoNormal"><span lang="en-US">Power 360W</span></p><p class="MsoNormal"><span lang="en-US">Motor Weight (Motor only) 60g</span></p><p class="MsoNormal"><span lang="en-US">Motor Dimensions (Diameter x Length) 28mm x 27.3mm</span></p><p class="MsoNormal"><span lang="en-US">Propeller Dimensions 8" x 5"/ 8" x 7"/ 9" x 5"</span></p><p class="MsoNormal"><span lang="en-US">Input Battery Types NiCd/ Nimh/ Li-po Battery</span></p><p class="MsoNormal"><span lang="en-US">Recommend Model Airplane</span></p></div>
