RE: Supra Fly 60 build
Chris,
nice work.
What do you have in mind for the fuse front bottom? Are you going to sheet and then add CF? What particular type of CF are you using for the pipe tunnel and formers? Are you bonding it with epoxy?
Is the SF45 cowl original you used any smaller than what is called for on the reduced 2500 plan? I would have thought the 45 cowl might have been a touch smaller than that called for on the 60 - not so?
Looking forward to the core work.
David.
