RCU Forums - View Single Post - programing esc
Old 05-08-2010 | 06:47 AM
Igoreski
Default RE: programing esc
The card on the right is the one for all V2 ESCs.This says Hobbywing but it is from Turnigy.Both companys are the same and just re label the products.People who have bad reviews with this did not follow directions.Use the upper right plug in for your chord that goes to the Rx and do NOT use the power plug in next to it unless you have removed the red wire from the ESC as this is the power supply for this 1 min programming.The face plates can be printed from your home computer,there are three of them for this card.Plane and helicopter,Boat,car and truck.All V2 ESCs work with this and the left one is V1 for planes and heli's.Here are the program options for boat. #1 Running mode. #2 # of lipo cells. #3 Low voltage cut off.#4 motor timing. If you call Aquacraft you can get the timing for that motor.Once you are done hit the OK button and recheck.This is the best $7 you have ever spent and you can change the values in the boat at the lake with no tools if you want to try timing / cut off changes ETC.
