ORIGINAL: JIMF14D
Mike, the new voltage high/low monitor functions sounds great. Can you give us any idea what the sample rate is for the down link data.
Also, besides having two antennas hanging out and 9 channels what is the major performance advantages of the 9 channel Rx? Are there two Rx hiding in there?
Jim D
Data refresh is 2 cycles per second I believe.
Essentially none; the boards are identical in all the Optima RX's. Maybe I should start calling them TRX's since they are transceivers and not just receivers. Also note that the range is equal to and from so you will never fly out of range of the telemetry unless you fly out of range of the radio which could only be done with FPV.
I believe we just got a large shipment of Optima 7 TRX's so they should be shipping shortly. Sorry for the delay!
Mike.
