RCU Forums - View Single Post - What does this mean?
Old 05-08-2010 | 06:57 PM
Argess's Avatar
Argess
Default RE: What does this mean?
as above.....a distorted glow-plug usually means it's too lean. Tuning requirements change with the weather. If it was running close to lean last year when you put it away, and it's a bit colder out this spring, then it will run lean at the same setting. So you need to richen it a bit. hmmmm.....hope I got that right
