RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
I went back to page 65 of this thread to look at the list of upgrades for version 1.07. I thought these 2 bugs (read next paragraphs) were on the list but they weren't. I recalled that someone had already reported these bugs somewhere on this thread:
1. After binding and setup a model to an Rx in Normal Mode, I went back to rebind the same model for the same Rx at Normal Mode again. I loose my channel assignment settings. I had to go back and reassign the Aux channels again. And I had to setup NORMAL/REVERSE for lost channels again. However, the EPA and program mixes are still there. I would like to rebind my model on Normal Mode once in while when I see lots of radio traffic at the field, especially at large events.
2. If I want more than 1 model setup in Scan Mode, I will loose bind on the first model when I bind the second model. If I go back and bind the first model, I will loose bind on the second model. I can only have 1 model bind saved when in Scan Mode? How do I retain binding when have more than 1 model in Scan Mode?
Can someone run a check to confirm my sanity please? Oh, before you do, please save your models on your PC to be safe. Thanks.
