RCU Forums - View Single Post - What does this mean?
Old 05-09-2010 | 02:23 PM
Argess's Avatar
Argess
Default RE: What does this mean?
You could have the LSN set a bit rich and the HSN set a bit lean. That way, you see lots of smoke when you accelerate, but near the end of the high speed run, the engine leans out and the glowplug becomes damaged. If you were to run at WOT a bit further, you would likely notice the smoke stops.
