RCU Forums - View Single Post - flight idle?
Thread: flight idle?
Old 05-09-2010 | 08:56 PM
Flypaper 2
Default RE: flight idle?
That's right, it does have more drag with the prop freewheeling. If it is slowing the plane down to much, crank up the throttle a bit till you get that glide speed that you want for decent approach, just above stall speed. Use your throttle as an elevator control.
