RCU Forums - View Single Post - Piston Ring Blow-By
Old 07-20-2003 | 02:59 PM
3 Channel Brain
Default Ring leak
All rings rotate on the piston if they are not pinned . try to catch
the end gap where u can see it.it should be .010/.020 max if more the ring needs replaced ( wear increases the end gap first)
(2) leakage of this sort is a cc per second type of thing & leak per piston stroke @ 10 or 12k is a minoramount per stroke.
