ORIGINAL: Ernie Misner
Don't gasoline engines run hotter than a methanol burner? Does Saito use the same exhause valve and clearances on the gassers?
Ernie
Yes, they generally except on the FG-30 & 36 there is a smaller exhaust valve to help make room for the NGK CM-6 spark plug.
