RCU Forums - View Single Post - Soldering a brass coupler to....
Old 07-19-2003 | 02:21 PM
Rodney
Default Soldering a brass coupler to....
You can use regular rosin core electrical solder. You can also use a silver bearing solder "Staybrite" is one brand name, but the regular solder does fine. Just clean the rod very well (fine sandpaper or file)j, clean with alchohol, tin the rod and then solder the coupler on by heating the coupler hot enough to melt the tinned solder on the rod.
