Soldering a brass coupler to....
I just did some couplers on 2-56 rods, i heated the rod & put a little solder on the rod. Then i took the brass coupler & held it with a pair of pliers & heated the coupler with a butane cigarette lighter, then slide the rod into the coupler, worked great, then heated the rod right @ the edge of the coupler & added a little solder to the joint.
Gil
