Hi Everyone
Well, finally got the chance to test heli this weekend. After setting the needles as described previously, it started like a dream. Transition from idle to full throttle was a bit sluggish and at one point sounded like it was ready to quit but then picks up rpm very quickly and smoothly. Adjusted the high needle from 3 turns out to 2 1/4 turns out, now it runs with no transition issues or leaning out. Only running 80% throttle on the throttle curve
, running +-2000 rpm on the head fairly constantly. Tried the governor(zero a) out but does anyone know how to get this thing to work? Magnets, spacing & everything installed as per manual. Have it setup on my flight mode switch but when engaged it sounds like you are blipping the throttle very quickly. Some say theirs either doesn't pick up rpm, others say theirs picks up to much rpm. Should I maybe bin this governor? Which is the "better" governor to get? Don’t need top of the line stuff yet
Cheers
Gavin
