RE: 3 blade prop question
having dual drive is to provide additional stability by counter rotating. You effectively eliminate prop walk and torque roll. by having twin drives turning the same direction, you have twice the sideways pull and friction in the water.<div>
</div><div>Use 2 motors into a single drive with a larger prop if it's speed your after.</div>
