RE: Pilot Extra 260 wont land
Hutchi, your plane may have the same issue as mine. Not only did the CG have to go forward 2 inches it also needed considerable right thrust put on the engine. I needed to add 2 washers thicknesst to get it to fly correctly. Before it would pull strong to the left in a vertical up line....put a couple washers between the standoffs and engine...that solved the problem.
