RCU Forums - View Single Post - Evolution TPS Engine Modification Experiment
Old 05-13-2010 | 12:19 PM
N Stal R
Default RE: Evolution TPS Engine Modification Experiment
Yes, I am trying to address the Evolution Trainer Power System (TPS) or part number EVOE100.
Ran the engine again yesterday at dusk with touch & go's with no problems.  I will need to work on the tuning on the low speed.
So far I have left the limiter on the low speed because it makes field adjustments much easier, once I get the adjustment within the limit stops.  I have found that the low speed adjustment is very sensitive.  You can go from lean to rich with very little movement (1-2 hour or 1/12th to 1/6 of a turn).
I have not tried to remove the muffler baffle.  Is that straight forward?
