ORIGINAL: skirack
The display on the Turnigy charger looks identical to the Thunder AC-6 charger found at
http://www.hobbypartz.com/thac6smbachw.html. I suspect they are using the same programming chip that was probably cloned in several units in the knock off world.
A big plus with the Thunder AC-6 is that you can run off AC or DC current.
skirack, this warning is found on most Turnigy chargers page @ Hobby King:
ATTENTION.
There are several chargers now entering the China market that look similar to the Accucel-6. These chargers are produced with cheaper FETs and unfortunately much less accurate and very unsafe. There has been reports of the copied chargers over-charging packs and not balancing correctly.
Our chargers have CE and RoHS certification, proving there safety. Plus, thousands of customers the world over have used our chargers with excellent success.
Your batteries are expensive. We understand this and thats why we will not carry low-quality charging devices.
