ORIGINAL: NM2K
Don't let those stick and glue kits scare you. They look much more ferocious to build than they are. You will need a razor saw and a sanding block. Neither is expensive. Other than that, you'll have a ball putting the Telemaster together. Good luck and enjoy.
I would use a .91 thru 1.30 four-stroke or an .75 thru 1.20 two-stroke for lifting cameras, etc. Yes, it would probably fly on a strong .40, but lifting a payload is another matter.
Ed Cregger
Thanks Ed,
I think I have decided that I will go with the Kit. I gotta learn sometime! I've got a razor saw and plenty of sanding blocks and a bunch of CA. It will be a good learning experience for me and I am in no rush to get her flying. I would like to build it a little a stronger anyways and make the wings bolt on. I believe I will need to purchase some type of table to work on though as I dont think carpet will do really well for building. While I'm building it I will continue to look at motors and try to find a good used1.20-1.50 saito 4stroke. Thanks for the information so far guys. Ihope to purchase the kit within the next week and I will keep posting updates in this thread as the build goes along.
