RCU Forums - View Single Post - JetJoe OWNERS thread
Old 05-14-2010 | 10:02 AM
  #2793
Xairflyer's Avatar
Xairflyer
Default RE: JetJoe OWNERS thread
It depends on how long it is lying up, yes it will seem stiff if the bearings are gummed up, also the preload could be stuck, I would strip it, you only need to undo the front spinner nut and pull the turbine wheel/shaft out as one unit, that way you will have access to the preload as well.
