RE: carbon fiber control horns
Carbon fiber does not always take glue so well. And there are not tremendous loads placed on the control horns of a plane that size. If you want more strength just use a thicker plywood horn. You can trace the outline of the stock horns onto new wood and either add another layer to the stock horn or cut new ones from thicker plywood.
