RE: seagull Decathlon
If the wing has incidence/anti-rotation pins, then it should be OK to bolt it. The pins will hold the halves together so they don't twist and the tube will still brace the joint. The leading edge pins and trailing edge bolts plus being pulled against the fuse edges will do the rest. My GP Giant Super Sports works that way. Also properly adjusted wing struts will carry some of the load.
