RE: RCGF Engines
Thank you T.O.M. Only problem with that is I would have to take the carb off in order to lay the template on the back of the engine.
I also note that the center circle as printed on the template is off by 3mm, does this mean I simply use the + lines or do I lower the horizontal line to take account of this 3mm.
Falcon
