RCU Forums - View Single Post - CG question
Thread: CG question
Old 05-15-2010 | 12:17 PM
highhorse's Avatar
highhorse
Default RE: CG question
Yes, it could lead you to false conclusions about the CG.
Same as any other plane, jet or otherwise. If ur low wing plane seems "wobbly" and as if it has a very tiny balance zone then flip it over so that more weight is "hanging" below the points of contact between the wing and whatever balancing mechanism u are using.
Otherwise, the model may not seem to balance anywhere.......first tipping forward and then aft when balanced at the same point.
