ORIGINAL: highhorse
Yes, it could lead you to false conclusions about uf CG.
Same as any other plane, jet or otherwise. If ur low wing plane seems ''wobbly'' and as if it has a very tiny balance zone then flip it over so that more weight is ''hanging'' below the points of contact between the wing and whatever balancing mechanism u are using.
Otherwise, the model may not seem to balance anywhere.......first tipping forward and then aft when balanced at the same point.
+1 highhorse is corect.
CG must be lower than the "pivot point"
my 2c
