RCU Forums - View Single Post - adding caps to esc
Old 05-16-2010 | 06:15 AM
norbique's Avatar
norbique
Default RE: adding caps to esc
The number of capacitors you add depends on the capacity of the capacitors. I used 5 pieces of 1000uF caps = 5000uF, which is already a big help to the ESC. You can go higher if you want, it won't hurt, but the more capacity you want, the bulkier things will become. You decide.
