RE: YS170 CDI difficult start
After I get teh first prime of the day into my pump it works flawlessly. Did you buy the engine already assembled as a CDI or did you put the head and backplate on it? You might want tot pull the head and make sure the pump is seated properly in any event, other than that check the tube that goes from the pump to the cam bearing for a pin hole.
