RE: Prop Size
Smaller prop with more pitch gives you more speed. Bigger prop with less pitch "bites" a bigger hole in the air and gives you more thrust. You will end up buying 3-4 props and fly them all to see which one you like best. I just tested props today and found "the one" that works best. Scoot
