RE: another darn ryobi post (ryobi performance modification, analysis and comparison)
The only thing I see with your flywheel, that may be a concern. It appears that you buffed the center of the flywheel. Thats the area that your prop adapter will ride. If that area is not true it may cause your prop adapter to not run true and vibration may result.
