ORIGINAL: w8ye
Many two stroke engines have pinned rings to keep the ring gap in one place so it doesn't get hung in a port
There is a pin down through the ring land or straight into the ring land
There is a notch in the ring that fits over this pin. It locates the ring gap away from any intake or exhaust ports
If you try to fit the ring any other way, you cannot get the piston in the cylinder
Ah good to know thanks for the info.
