RCU Forums - View Single Post - trouble with engine
Old 05-17-2010 | 02:51 PM
bigdogkanicsar's Avatar
bigdogkanicsar
Default RE: trouble with engine
first it sounds like the flywheel retainer nut is loose, you have to remove the clutch bell to see it. second are the fuel lines hooked up backwards, or maybe you might want to clean out the engine and carb really well as there may be junk in the lines or rust deposits in engine and/or the carb.
