ORIGINAL: trainer25
ill clean the carb, lines were correct, any suggestions on how and what to clean the carb with?
If the carb is made of alum then i use break cleaner it desolves everything pretty quick just be sure to keep it off rubber parts if you can .
if its a plastic / composite carb then i use wd40 .
