ORIGINAL: krashkart
Did anyone fly floats with the smaller motors?
I will assume that longer takeoffs were OK?
The problem with floats is proper mounting. If they are mounted correctly and you have master the proper float flying technique a saito 56 is plenty.
But to have the float step in the wrong place or the mounting incidence wrong and you need a bigger engine to overcome the problem you created.
