RCU Forums - View Single Post - Hobbyzone Mini Super Cub Problem - Please help
Old 05-18-2010 | 11:30 AM
Mr67Stang's Avatar
Mr67Stang
Default RE: Hobbyzone Mini Super Cub Problem - Please help
Take the cowl off. With the plane turned off and battery removed, turn the prop by hand while looking at the shaft comming out of the motor and the center of the prop. Look for a wobble. If it apears straight. Install the battery and carefully hold the plane and observe the prop and prop shaft for a wobble. If it wobbles, it is bent.
