RE: TT 53 Redline leaning out
Hi Barracuda
Finally got a chance to check cyclic throws last night on the Titan 50 SE as you suggested and are as follows:
Up elevator = 11 deg
Down elevator = 10 deg
Left aileron = 9 deg
Right aileron = 9 deg
Trex 600N cyclic throws are about 10 deg for both elevator & aileron.
If I understood you correctly about total pitch, I gather then that you would add your collective pitch and you cyclic pitch together to get your total pitch range. if this is the case then I'm seriously making a mess of my setups. with a max of 14 deg on collective and 9/11 deg cyclic, I would then be running between 23/25 deg total pitch. that would kill my new raptor very very quickly[&o] as stated before, I always just make sure my ATV for pitch, elevator and cyclic are as close to 100% as possible without causing any binding. good thing we can come on this forum and learn new things every day. What should the total pitch be and whats the max cyclic throw thats most efficient? I know mine doesn't bog down at the moment but yes I don't exactly bang my stick around either.
Cheers
Gavin
