RE: FOX COMPOSITES Bae HAWK, Build thread
These little beauties arrived today. Jet 1A main leg oleos, nose oleo and forward retracting nose retract with built in steering arm. this is a fine piece of work, the ball link on the steering arm does not vary in position either vertically or laterally during the retract cycle, just a very small sideways movement of the steering rod from the servo which will pass through a slot in the mounting former. Retract angle is around 115 degrees so the former can be fitted vertically, going to work on this next as it looks like a nice easy install!
John
