RCU Forums - View Single Post - styrofome
Thread: styrofome
Old 07-23-2003 | 08:13 PM
Demon
Default styrofome
Originally posted by Goku
How do you thin epoxy?
Rubbing Alcohol works great to thin epoxy. Be sure to use alcohol that is as close to pure as you can because water (commonly used as a dilutant in rubbing alcohol) significantly slows the cure time.
tlcdennis,
Are you planning to paint a raw foam model?
For what its worth, covering the model first with either packing tape or a low-temp, iron-on covering (such as TowerKote or EconoKote) will not only provide a fuel-proof barrier over the foam, it will also make the model MUCH stronger.
HTH,
D
