RE: stampede spar gear kepts going bad
Make sure you're getting the right spur for the truck. The white one you used is either for a different car (wrong), or an aftermarket (like Robinson). Make sure it is the correct pitch. The Traxxas original spur for your truck is molded in black composite. White spurs usually go on the electric trucks.
