RCU Forums - View Single Post - Fuel Pump Plumbing Tutorial
Old 05-20-2010 | 02:16 PM
AndyAndrews's Avatar
AndyAndrews
Default RE: Fuel Pump Plumbing Tutorial
ORIGINAL: KFX450
I have a quick question,
I noticed you were using the polyurethane tubing, hard, stiff,..correct?? Is tygon tubing reliable, in this method, coming from the UAT to the pump??? What are your thoughts??
I wouldn't use tygon between the UAT and pump. Tygon is soft and can collapse restricting the flow. Use the poly tubing.
