RCU Forums - View Single Post - FPE 2.4 problem
Thread: FPE 2.4 problem
Old 04-08-2002 | 02:50 PM
Antique's Avatar
Antique
Default FPE
The coil can't be the problem if it fires at all..The ignition circuit determines the firing point..IF IT RUNS BACKWARDS THE TIMING IS RETARDED OR THE PRO SPARK IGNITION IS BAD....If the timing is fixed it was installed in the wrong place, or the hub somehow slipped on the crank...This is not rocket science...
