RE: Difference between 72 PCM AND 72 PCM1024
Thats a 512 transmitter and only works with the original release PCM recievers. If it's labeled 1024 it won't work.
The stick throw is broken down into steps, in the case of the original PCM that was 512 steps. Newer systems added a bit to the encoding scheme and increased the stick resolution to 1024 steps (they have 2048 now)
Anways, it's doing as it is designed to do.
