RE: New CDI - opensource project JMJ and Bigboat
I'm glad a made the CDI with a PIC bracket so i can take the Pic out and put it directly on the rcd programmer. And yes, i'm using the adapter for this. Grrrrrr. After changing the capacitor to 470uf it still doesn't work and getting errors with verifying.
Would it be an idea to adapt the programmer to the 2.3 version and set voltage on mclr at 5V . Then use low voltage programming? Would that give the programmer more time to program and verify before the capacitor is discharged?
